Posted by cob_crusher on May 04, 2010 at 12:04:38 from (24.213.205.227):
changed hy filter (left side motor & hy pump). cleaned o-ring carefully on cannister, tightened clamp & bubble tested for air leaks. added hy fluid until front axle sight glass full. put hy end with 3000 psi gauge in aux remotes. showed 2000 psi. cleaned pilot system relief valve (by valve stack -- behind right shoulder) check end of relief valve for dirt & check o-ring for good seat. when i opened valve cap was an air build up. was pre-venting full pressure to lift cylinder on disk. works aok now.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
