Re: new grease turning to oil?
Posted by M Diesel on May 04, 2010 at 13:49:05 from (12.24.61.12):
In Reply to: new grease turning to oil? posted by rustyfarmall on May 04, 2010 at 05:26:32:
rustyfarmall said: (quoted from post at 05:26:32 05/04/10)
I installed new wheel bearing in an H 2 weeks ago. I packed them with the red EP grease, and in the 2 weeks, not one drop has oozed out or dripped out.
I'd venture to say you have better seals. 8)
I have one tub of red stuff that (in the summer) will slowly pool oil on the surface just setting there. I suppose it just depends on the vagaries of the mix. One of the pluses to the old thick stuff is it helps form a barrier, supplanting the MIA seal lips. Not a great idea, but it is what it is.
