Re: new grease turning to oil?
Posted by Farmer Devin on May 04, 2010 at 13:54:45 from (72.173.192.58):
In Reply to: Re: new grease turning to oil? posted by rustyfarmall on May 04, 2010 at 05:26:32:
I did add grease fittings and zerk caps to the hubs and pumped them full after packing them on the bench. However it is extreme pressure grease, you would think it would take the pressure from a hand operated grease gun. lol. Yes, the hubs and beaings are always well dried when I've had to flush them out with solvent. I noticed in the tub of grease before I used it, that there was a small puddle of oil in the lowest point. I've seen that before, but not that much. There was no oil spilled in the grease.
