Re: Posted on Tractor talk by mistake... Starter ???
Posted by Jim Becker on May 05, 2010 at 07:23:07 from (173.57.149.7):
In Reply to: Posted on Tractor talk by mistake... Starter ??? posted by dave2 on May 05, 2010 at 01:05:13:
It seems likely the problem is the starter drive. Wayne's comment that the drive is a non-Bendix drive is probably true although there are a lot of solenoid controlled starters with Bendix drives. Doesn't matter what type it is, you need the specific one that works.
Low voltage to the starter could be the problem. Low temperatures reduce battery output and bad connections will loose more power. So before replacing the starter, make sure the battery, wiring and grounds are in good shape.
I found a reference to a French company that supplies after merket starters. The company is ADI Original and their replacement starter is DEM119. Their cross-reference lists the following starters as replaced with DEM119:
Bosch
0001354026
0001354094
0001366019
EJD1,8/12R61
ELSTOCK
25-1350
DUCELLIER
6163
Maybe that will help you find a replacement drive.
