Re: Bull Pinion Cage Shims and 4th/5th Gear
Posted by mkirsch on May 05, 2010 at 09:58:07 from (64.80.108.56):
In Reply to: Bull Pinion Cage Shims and 4th/5th Gear posted by Kevin in MI on May 05, 2010 at 08:28:51:
Any old tractor salvage yard in the country should have a dozen or so of the gears you need in stock. The H was the most common Farmall model, ever. Just look in the yellow pages.
