Re: Farmall Super H - cam upgrade?
Posted by RTSMikeM on May 05, 2010 at 11:25:35 from (70.97.180.27):
In Reply to: Re: Farmall Super H - cam upgrade? posted by ChadS on May 03, 2010 at 14:38:51:
Chad, Thanks for the details.
A few questions:
1) Does the 3.5 overbore kit require machining or just drop in new sleeves? Also where to buy the kit & pistons?
2) You said to use an H gas head casting number 8043DC. Why an H head? What makes this head different from what I've already got in the Super H?
3) Will my stock carburetor work? Hoping so.
Maybe bigger jetting inside?
4) So leave the cam alone? I thought it might be good to get the intake valves to open earlier...
5) I would like to leave it 6 volt. Turns over fine for now. Do you think higher compression will force me to 12 volts?
Thanks for the info!
Mike
