overrunning clutch Farmall h
Posted by RMOMN on May 05, 2010 at 16:08:48 from (64.122.139.56):
I bought a overrunning clutch for my H and it looks like they want you to drill a hole through the pto shaft to install a roll pin to retain the clutch assembly. Has anyboby installed one of these or is there a better clutch available
