Re: Which F model should I buy?
Posted by Tom Fleming on May 05, 2010 at 18:31:51 from (67.20.229.132):
In Reply to: Which F model should I buy? posted by Farmall F Series on May 05, 2010 at 15:12:10:
Personal experience. I have an F-12. Fun little tractor, but not much power and the carb/fuel pump setup can be cantankerous. But, I own one, and I have no plans on selling it.
I love my F-20. Period. Probably my favorite tractor with the '42 H running a close 2nd.
If you are going for rare, then the first responder called out F-30's, narrow tread, early regulars are very desirable.
If I could pick only one to start with, I would pick the F-20. Most parts available for it. Lots of them out there. Easy to work on.
As always, IMHO. Personally, I don't think you could go wrong with any of the F series.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
