Narrow tread is the rear axle width. My F30 is 102" wide making a deckover the only option for a trailer. Narrow treads fit on most trailers and don't take up as much space in the shed.
Most guys are looking for F and H round spokes if they want rubber tires. These were factory setups. Alot of these tractors were converted from steel and have cutoffs, the steel tires/wheels were cut off and rims welded to the flat spokes.
Cut offs are probably least desirable, late model tractors could also have cast centers with galvanized rims like you see on h's and m's (very desirable).
There are a multitude of tire and rim sizes, rubber and steel, that were used on the F series even duals. All part of the fun. Steel or rubber is a matter of your preference.
This post was edited by 36F30 at 20:22:38 05/05/10.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
