Re: Which F model should I buy?
Posted by F-Dean on May 06, 2010 at 06:05:24 from (75.206.81.138):
In Reply to: Which F model should I buy? posted by Farmall F Series on May 05, 2010 at 15:12:10:
I would start with a F-20 (I started with my Dad"s). It has the basic F-Series engine and parts (new and used) are readily available.
From there you can branch out to the more rare (and more expensive) models.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
