Re: Which F model should I buy?
Posted by BOBM25 on May 06, 2010 at 09:13:46 from (74.218.59.34):
In Reply to: Which F model should I buy? posted by Farmall F Series on May 05, 2010 at 15:12:10:
F14 or F30. The slanted steering shaft makes them look a little better, I think. Kinda sets them apart from the others
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
