Re: front tires for a farmall A
Posted by farmer_adam on May 06, 2010 at 14:09:02 from (216.99.185.50):
In Reply to: front tires for a farmall A posted by Craig Blumke on May 06, 2010 at 09:18:48:
Tractor Supply sells them. They are 4x15 which will fit on a 3x15 wheel. They should have a tractor supply nearby, the only things is that they cost around $70 a piece.
