Timing check needed. Remove plugs. Put thumb in #1 plug hole Turn by hand or bumping starter (coil wire grounded) until air blows out of #1 hole Put a plastic straw or copper wire in the cylinder (through plug hole) to piston. Turn slowly till wire stops moving up. Look at timing marks and see where rotor is pointing. Timing mark should be on the TDC (last) mark in the rotation direction. Rotor points to 1:30 (from rear)
If not like this it may have broken timing gears. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
