stuck governor
Posted by rustytenn on May 06, 2010 at 18:48:22 from (206.74.91.39):
i recently gotten a farmall 140. the tractor set outside and had not run in a couple of years.it will only run at half throttle.i can manually move the linkage on left side of tractor and get it to run wide open but not using the throttle.all the linkage moves fairly easy.will the governor need to be took off and cleaned?the carb moves fine its the governor that feels a little sticky. thanks
