Re: I broke it....(carb problem)
Posted by Bob on May 06, 2010 at 21:45:59 from (69.178.228.68):
In Reply to: I broke it....(carb problem) posted by ADLM on May 06, 2010 at 17:46:08:
Manufacturer's part number (Zenith) is C38-51-15.
See if Zenith Fuel systems can help you or refer you to someone that can.
You might also try TheCarburetorShop.com.
