Re: Do I need a new hydraulic pump, on my international 140?
Posted by gene bender on May 07, 2010 at 04:48:11 from (207.177.56.155):
In Reply to: Do I need a new hydraulic pump, on my international 140? posted by LotFotL on May 06, 2010 at 18:06:37:
You need to change the seal in the hy pump as its leaking the fluid into the crankase. I f the shaft is worn at the journal then you will need a speedy sleeve to get that aarea of tha shaft correct so the new seal can stop the leaking into the engine.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
