Re: High speedlowreverse attachment on 51 M
Posted by mkirsch on May 07, 2010 at 05:29:14 from (64.80.108.56):
In Reply to: High speedlowreverse attachment on 51 M posted by Don in MN. on May 06, 2010 at 14:04:08:
Don,
What you have is one of the "9 speed" conversions, not a "high speed low and reverse." The person who sold you the tractor really didn't know what he had.
The 9 speed gives you 4 more gears between 4th and 5th. You activate the gearbox by pulling the cable, and then use gears 1-4 to get the higher speeds.
Like any other gear the tractor must be stopped to shift.
Parts are just about impossible to find, but a cable is a cable. You should be able to find a suitably stiff cable to replace the original if you remove it and adapt it with a little fabrication skill and creativity.
