Re: A-192 plow
Posted by El Toro on May 07, 2010 at 05:39:44 from (74.103.74.58):
In Reply to: A-192 plow posted by Farmer_Adam on May 07, 2010 at 03:45:35:
third party image
I don't know if this picture will help, but back in 1976 I didn't have a manual and I ask several people at our local IH shop if they knew how to install it. None of them knew how so I pulled the tractor along side of the plow and had it installed in a few minutes. All the mounting brackets were on the plow and they attached to the underside of of the tractor. All the levers used for tilting the plow point and for raising the plow were easy to attach. You need to reverse the drawbar too. Hal
PS: You can try binderbooks to see if they have a manual. I'm sure they do.
