rustyfarmall said: (quoted from post at 07:13:56 05/07/10)
ADLM said: (quoted from post at 17:46:08 05/06/10) I was rebuilding the zenith carb on my Farmall A. All was going well, until I broke the venturi. Where do I find a replacement, and how was I supposed to get it out? (venturi no. 15, IH part 62171D)
The venturi is supposed to just lift outm but due to dirt and crud building up around it, they quite often DO become very stuck. Soaking the entire carburetor in GOOD cleaner (not Berrryman's) overnight will usually loosen up that crud. If that doesn't work, you can use a small propane torch to heat the area around the venturi, and then spray that area with penetrating oil while it cools down, and then just walk away from it long enough for it to cool completely, after which you should be able to slowly get it to move by gently trying to turn it with a pair of small channel locks. Those pot metal venturis are very fragile and WILL NOT stand up to any kind of abuse.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
