First of all, one doesnt need to Re Poalrize very often, only perhaps if the genny has set unused for a really really longgggggggggggggg time or if its been to a shop and had work and possibly got Polarized at the incorrect Polarity, or one reversed his battery polarity...
Next NO YOU DO NOT POLARIZE THE GENNY EVERY TIME YOU TURN ON THE IGNITION...To Polarize you have to pass current through the gennys Field windings which imparts a certain degree of residual North/South magnetism in the soft iron Field Poles encircled by the field windings. BUTTTTTTTTTTTTT theres no connection created by turning on the ignition from the battery to the genny (for any field current path) since the cutout relay (between VR's BAT and GEN/ARM) is still open. IE turning on the Ignition switch DOES NOT cause the gennys Field windings to conduct current which is required to Polarize. Its when you by flash jump hot battery voltage (such as present on the VR's BAT terminal) to the VR's GEN/ARM terminal or gennys ARM post (which is connected internally to the Field coils) that the fields draw current setting the North/South residual magnetic field in the correct orientation.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
