Removing clutch on a Super M
Posted by PPP on May 08, 2010 at 08:33:23 from (67.142.163.28):
Working on changing clutch through bottom hole on a Super M (12 inch clutch). Don't seem to quite be enough room to get the assembly out. I remove drive coupler, spring, clutch cross shaft, compressed pressure plate with 3 - 5/16 bolts, removed pressure plate to flywheel bolts.... Do you have to remove anything on transmission side of coupler? Or is there something special about the angle the shaft has to be in before it will drop out?
Thanks for any help!
