Re: H REAR WHEEL
Posted by wayne in mn on May 08, 2010 at 16:57:54 from (24.179.175.173):
In Reply to: H REAR WHEEL posted by BERGIE on May 08, 2010 at 11:10:29:
When you jack up the "offending" side, notice how much up-down and side-to-side play there is. Your axle bearing may be very worn causing a gear to lock up.
Remove the brake cover and check the brake pinion bearing by moving the brake drum up & down.
