Re: Farmall F20 Spoke Wheels
Posted by robgIN on May 08, 2010 at 17:25:19 from (70.224.39.135):
In Reply to: Re: Farmall F20 Spoke Wheels posted by 55423 on May 07, 2010 at 20:11:14:
if they are flat spoke cut offs the bolts will be sticking out only the thickness of the bolt head if this is what you mean by flush. These were originally steel wheels which had the spokes cut off and pneumatic rims welded on. Maybe these are one of the versions you are seeing. Flat spokes are definitely wider appearing than round spokes.
