Re: Rebuild engine or leave alone
Posted by rustyfarmall on May 09, 2010 at 13:58:35 from (209.152.78.140):
In Reply to: Rebuild engine or leave alone posted by John M on May 09, 2010 at 10:29:00:
John M said: (quoted from post at 10:29:00 05/09/10) The smoke from the oil fill tube is normal, and the blue smoke your seeing is probably from unleaded gas. Mine has been rebuilt and it does the exact same thing, in fact, pretty much all of my tractors do the same thing.
Smoke from the oil fill tube is nothing to be overly concerned with, but that smoke DOES indicate the compression rings are worn out, and the blue smoke from the exhaust indicates worn out oil control rings. Unleaded gas does not make blue smoke. Too much unleaded gas, or ANY gas for that matter will make black smoke if too much is fed in.
