Re: slime in tires
Posted by FarmerDevin on May 09, 2010 at 17:39:35 from (12.189.32.54):
In Reply to: slime in tires posted by charlie M on May 09, 2010 at 13:39:42:
It has worked good for me. I only use about half as much as they say and it has worked fine. Fixed a 15.5 38 with it once. Worked great until it got below freezing. Then the tractor could be down for two days. Haven't had a tire shop ask about slime. I always blow compressed air in the valve stem before putting the valve back in, otherwise the valve might not seal with the particles in the slime.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
