Re: Plowing with the H (short video)
Posted by rustyfarmall on May 09, 2010 at 18:21:50 from (209.152.78.140):
In Reply to: Plowing with the H (short video) posted by Wilamayb on May 09, 2010 at 14:58:16:
Wilamayb said: (quoted from post at 14:58:16 05/09/10) Also... If you have to plow as deep as the roots will go why would no-till work?
If you plowed as deep as corn roots you would have to go at least 10 feet. I'd like to see that.
Plowing in the past was only because you had to get the soil loose so that cultivation could take place and there was really no disk to get the job done. It required the plow. Now that cultivation is not necessary due to modern herbicides there is no need for the plow unless you need to turn the sod over in a hay field.
No-till means you do not till the soil before you plant because the no-till planter does the tilling and planting all in one operation, and tills the soil ONLY where the seed is deposited.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
