Posted by Jim Becker on May 09, 2010 at 18:36:26 from (173.57.149.7):
In Reply to: Super C Hydraulics posted by jeffalex2 on May 09, 2010 at 15:31:43:
If there is no movement of the rockshafts and the system doesn't seem to be laboring under high pressure, the most likely problem is the pressure control orifice. There should be a pipe plug in the Touch-Control head. Take the plug out to access the orifice. Unscrew it and make sure it is clean. Reinstall and see if that fixes it. If not, go into more complicated diagnostics.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
