Posted by Janicholson on May 10, 2010 at 06:49:37 from (199.17.6.222):
In Reply to: SMD Fuel Pump Leaks posted by Brian Schmidt on May 09, 2010 at 18:09:09:
If it seems to be leaking diesel fuel the issue is internal. There is not supposed to be diesel fuel in the body of the pump at all. If there is the Plunger and rack system is ni need of seals at least. If it is engine oil, it is a matter of changing gaskets etc. The covers are not critical in position, so making gaskets from new bulk material is fine. The pump does not share oil with the engine. It is filled separately and has a level plug (or petcock) on the outside to check level. If it is filling it is likely to be filling with diesel. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
