I will add the other aspect to short life of a voltage regulator. Now days, one generator fits all or nearly all of the old farmall tractors when in reality the ones that came from factory with a high low charge switch had an entierly different current flow through the field coils than the models that came with voltage regulator. I have been cussing rebuilt generators since their inception as they don't match the original equipment. I used to always use genuine delco remy parts to repair generators is at all possible. If a generator came into the shop that was a rebuilt unit, then I normally just sold another rebuilt one as you could not match parts to fit a good share of the time. Wrong field coils, armature turned down to nothing, shafts cut for undersize bushing, wrong brushs etc. Way too much current flowing through most of the voltage regulator vibrating contacts to sustain clean contact surfaces for long. Once I had a new 706 that was eating up voltage regulators, and this was back when they made good 3 unit regulator, the voltage out put was eratic which of course could not be detected very well by the owner as it had an idiot lamp, no ammeter. I took generator apart and found that the current flow through field coils matched a 6 volt generator , all other parts were correct. Replaced field coils, problem solved.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
