Re: christmas tree valve
Posted by rtb321 on May 10, 2010 at 17:53:37 from (72.45.140.161):
In Reply to: christmas tree valve posted by rtb321 on May 10, 2010 at 12:57:00:
if that adjustment isn't holding the valve centered could that be causing my problem?....THE PROBLEM...when i use the the one way hyd valve on the reservoir under the gas tank, the lever on the christmas tree valve slams forward and pushes the fluid through the pressure relief valve.....THE TRACTOR...is a stageII super m with live hyd. the christmas tree valve is plumed into the pressure hose from the pump with an aftermarket pressure relief valve, then the return side goes to the pressure in side of the reservoir to supply that. basicly i'm running pressure through the christmas tree valve to the reservoir so i can have two seperate hyd. controls. any ideas?
