The christmas tree valve is normally plumbed into both the pressure and suction lines with live pump. Pressure comes in the side and suction out the bottom. They inturn are plumbed parallel to rear tank. When using double action cyl,you lock the lever for the rear box and the oil recirculates through the christmas tree valve back to pump when in neutral. When raising imp oil is exposed to relief valve in reservoir. When using single action cyl, you lock the christmas tree valve and release rear lever using it to raise and lower imp again using same relief valve in reservoior. I don't know why you would have a seperate relief valve plumbed into system. Isn't a flow divider for power steering is it. At any rate, if christmas tree valve is not centering it would not hold a loaded double action cyl. Look at the on line parts manual under caseih for a layout of the connections.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
