Posted by caterpillar guy on May 11, 2010 at 03:59:55 from (66.188.53.165):
In Reply to: 886 no stop..... posted by mh on May 10, 2010 at 19:34:38:
It is the throwout bearing. If you take the plate off under the clutch you will find the pieces laying at the bottom. I bet you didn"t know there was a grease fitting for the throwout bearing up in there. We just did all that to our 806 last year. I put a grease line to a bulkhead fitting in the plate so I can grease it from under the tractor without having to remove the plate.
While your in there look at the constant drive spline that goes into the back of the pressure plate if it is worn excessively change it. That runs your PTO and hydraulics. if that has the TA it is real easy to replace that just 3 bolts and pull out. Change the pilot bearing while your in there too. I just cut them out with the torch. Becareful about the heat if you do.I cut the race out then knock the pieces out then cut the other race out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
