Re: A Question for Mr. Rustyfarmall/M Carb Rebuild
Posted by Theman on May 11, 2010 at 08:34:24 from (65.198.133.254):
In Reply to: Re: A Question for Mr. Rustyfarmall/M Carb Rebuild posted by Coax on May 11, 2010 at 08:20:18:
I had the same problem with the idle jet on an H. The first thing to do is put a small braze tip on your torch and heat just the brass jet part broken off in the threaded hole. Don't get it hot enough to melt. Allow it to cool completely. If you find an EZ-Out or left-hand drill as mentioned, use it to remove the stub. Short of that, drill then re-tap with, I believe, a 5-40 tap. Please verify this size with the jet that comes in your kit as it was more than a few years ago this happened to me.
