Re: A Question for Mr. Rustyfarmall/M Carb Rebuild
Posted by old on May 11, 2010 at 08:48:43 from (4.245.7.88):
In Reply to: A Question for Mr. Rustyfarmall/M Carb Rebuild posted by Coax on May 10, 2010 at 21:59:14:
A small E-Z out or you can also use a small flat blade screw driver and drive it in, make sure it is not wider then the treads in that area. Then twist it back out. BTDT on carbs and didn't have a small enough E-Z. out but did have the screw driver. You can clamp a vise grips to the screw driver if you need more twist power
