Loose clutch rod on the H
Posted by T-Tim on May 29, 2000 at 14:37:58 from (209.255.78.170):
Got a "if it works don't fix it" question for my "H". The clutch rod from the pedal to where the rod enters the "bell housing"(?) has some play in it. It appears that a bushing at the point where the rod/shaft enters the housing has worn. When I depress the clutch I can see the shaft, which enters the cast iron bell housing, move within what should be a fixed position. I assume this shouldn't happen. Clutch works fine but I'm guessing I'm not getting the full use of the clutch. What do I need to fix this? Is it worth fixing?
Post A Followup
: Re: Loose clutch rod on the H
