Re: 1939 Farmall M with Detroit diesel at auction
Posted by Craig Thoricht on May 11, 2010 at 14:34:51 from (75.185.179.37):
In Reply to: 1939 Farmall M with Detroit diesel at auction posted by ryanwheelock on May 11, 2010 at 06:43:52:
Detroit Diesel engines were labeled as General Motors Diesel cast in the block and I"ve seen some stamped in the rocker covers as well. Those engines were developed for buses and marine use,as well. Almost every landing craft used in WWII used at least one of them,depending on size. Charles Kettering was instrumental in their design as well as the Allison V-12 used in aircraft.
GM was looking to get in on upcoming defense work with those engines and other projects.
Having said that the chances are the conversion very probably was made after the war because the government was buying those as fast as they were being made before the war.
A good way to check would be to get with someone from Detroit Diesel and have them do a serial number search on the engine in question. They have a data base for that. Should settle the question.
Regards-
Craig
