Re: Speedi-Sleeve on a Splined PTO Shaft?
Posted by Janicholson on May 11, 2010 at 16:41:49 from (199.17.6.222):
In Reply to: Speedi-Sleeve on a Splined PTO Shaft? posted by rumplestiltskin on May 11, 2010 at 14:42:41:
Clean and measure the shaft. If it is at all bigger than the seal location, it will not work from that end. Use at least a good caliper, and measure carefully. Some shafts are put together fron the inside out, and need to be taken apart to repair. We might be more helpful if we knew what it was on. Jim
