Re: IH 300 Utility Hydraulic Problem
Posted by IndyPung on May 11, 2010 at 17:44:58 from (75.204.25.159):
In Reply to: Re: IH 300 Utility Hydraulic Problem posted by rumplestiltskin on May 11, 2010 at 17:22:59:
I see in the archives where someone said to put a low pressure burst of air into the breather on top of the reservoir. Is that under the seat? The only thing I can see is the filler hole. Someone else said to just point the tractor nose down hill. Do you think that would work? Other said to take some piece off of the pump and put oil in it. I didn't see an obvious primer port on my pump, but it's old so I could be missing it...
