Make sure the intake manifold is secure to the head (not easy to see the nuts) They are brass and subject to stripping. Also make sure the carb is attached to the manifold w/o leaks. If it is tight and leak free, the carb may be plugged up internally. There is also the possibility that the intake manifold is cracked between the exhaust ports, and the intake. It is hard to find with the exhaust pipe still on it, but a possible issue. Try the manifold nuts and carb nuts and then try it again. If no better, the carb is next. It could be a failing coil or condenser, but choking it to keep it running popints to fuel. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
