Re: IH 300 Utility Hydraulic Problem
Posted by Dellbertt on May 11, 2010 at 18:21:57 from (209.172.22.172):
In Reply to: IH 300 Utility Hydraulic Problem posted by IndyPung on May 11, 2010 at 17:10:53:
The line that you removed on the left side of the reservoir is not an add on, it is supposed to be there.
The filler hole is on the front of the reservoir where as the vent is in the center. It should have a small air filter screwed into it.
The 5lb or less puff of air goe in the vent hole.
If JimN does not see this post, search his posts for a complete answer.
If you fill the lines from the reservoir to the pump you should not have a problem priming.
Dell
