Re: IH 300 Utility Hydraulic Problem
Posted by Janicholson on May 11, 2010 at 18:55:37 from (199.17.6.222):
In Reply to: IH 300 Utility Hydraulic Problem posted by IndyPung on May 11, 2010 at 17:10:53:
You can put as much as 25 PSI in the fill hole under the seat. Continuous pressure is needed to (force) prime the pump. The vent will need to be plugged, or you can use a tire valve to pump pressure into it with a tire pump. Down hill into a ditch, or loading ramp is also great. Jim
