Posted by pete 23 on May 12, 2010 at 10:15:58 from (173.87.144.56):
In Reply to: M starter switch posted by oldiron29 on May 12, 2010 at 09:34:23:
Good luck finding a good switch. However, the bigggest problem with the switch on the M is the way it is mounted. Most of the time, stomping on the lever or pin that operates the switch results in something other than a straight push on the button and therefore causes poor contact internally and damage to the switch. I have done several different modifications on them to get them to push straight but most are less than perfect. I personally like the switch mounted up on the steering post like on most of the H tractors. This works well if converted to 12 volts but with a 6 volt system it requires a lot of pressure to get a solid contact so does not work as well. Then the other option is magnetic switch operated by a push button but most of them cannot handle a heavy 6 volt current load or at least not for very long. So, back to square one.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
