Re: A Question for Mr. Rustyfarmall/M Carb Rebuild
Posted by rustyfarmall on May 12, 2010 at 13:14:17 from (209.152.78.140):
In Reply to: A Question for Mr. Rustyfarmall/M Carb Rebuild posted by Coax on May 12, 2010 at 10:37:22:
Coax said: (quoted from post at 10:37:22 05/12/10) Thanks Rusty, I wanted to make sure on the tap size. 5-40 was not standard and I couldn't tell what size the original was without damaging something. So the NEW jet will be #4-40??? The thing is so tiny, I could'nt tell if it was fine or coarse thread.
It is neither fine thread nor course. It is 40 threads per inch.
