gene bender - 100 touch control problems
Posted by couv on May 12, 2010 at 19:52:23 from (209.33.29.72):
Gene, I"d like your input - I changed o-rings in my 100 touch control & hydraulic lines.
Which ever Lift Arm has no load moves 1st.
Which ever Lift Arm has the load moves 2nd.
Switch load to other arm, problem moves with the load.
Both seem to move V-E-R-Y slowly unless engine is at high rpm.
Local mechanic fairly familiar with Farmalls thinks I have one of the 4 poppets in backwards.
What do you think ?
I"m still worried that my unit had a 5th small spring (one behind each poppet) and I put the 5th one in the cap between the pressure valve and the ball.
Any way it appears I have to pull the head off and look.
Can you shed any light or share any wisdom from your experience ?
