Re: Fixed: H wide front wobble - opinions on steel bushings?
Posted by rustyfarmall on May 13, 2010 at 06:13:45 from (209.152.78.140):
In Reply to: Fixed: H wide front wobble - opinions on steel bushings? posted by riverbend on May 13, 2010 at 04:51:38:
riverbend said: (quoted from post at 04:51:38 05/13/10) My H had a wobbly front end (Schwartz wide front). I discovered the bushings in the trunions were worn. Replacing the bushings (and tie rods since it was all apart) fixed the 5th gear wobble.
The replacement bushings from A&I were steel. The original bushings were brass.
I had always heard that if you run two hard materials together, you will get more wear on both parts, as compared to one hard and one soft. Examples: rod bearing and crankshaft or Amal Carb slides and bodies.
What do you think ? Should I find brass bushings and replace the steel ones ?
Thanks
Greg
A&I owns Schwartz, and still manufactures parts and complete new assemblies. I think they probably know what works and what doesn't.
