Re: H/M Carbs
Posted by rustyfarmall on May 13, 2010 at 06:20:37 from (209.152.78.140):
In Reply to: H/M Carbs posted by IndianaRed on May 12, 2010 at 16:28:00:
IndianaRed said: (quoted from post at 16:28:00 05/12/10) I keep seeing on the pulling board that SH and M carbs are the same? Doesn't sound right.
And then I see guys putting M carbs on H's. How do you make it fit?
The M carburetor will fit the H ONLY if you first install a manifold from a Super H through 350. A new replacement manifold will fit the H through 350, and has slotted mounting holes to accomodate either the H carburetor OR the M carburetor.
Installing an M carburetor on an H will NOT result in more power unless you have first made some serious modifications to the engine.
