Re: Fixed: H wide front wobble - opinions on steel bushings?
Posted by riverbend on May 13, 2010 at 14:53:12 from (74.46.180.225):
In Reply to: Re: Fixed: H wide front wobble - opinions on steel bushings? posted by Dave_Id on May 13, 2010 at 10:55:22:
The new bushings do not have grease holes drilled in them. The old bushings had holes in 3 different locations. One per bushing, but drilling them all without knowing where to put them for each grease fitting would not have worked.
I was reluctant to drill through the hole for the zerk for fear of buggering up the threads. The original hole was 11/32" so it was easy to get the bushings installed close enough to work.
Greg
