Re: CRANKSHAFT PULLEY
Posted by old on May 13, 2010 at 15:39:16 from (4.245.1.186):
In Reply to: CRANKSHAFT PULLEY posted by mathew koetting on May 13, 2010 at 15:34:52:
Check the archives and if you look enough to will find pictures of one Keith made to pull those pulleys. I uses a hyd jack and some other stuff to do the job. Or maybe you will get lucky and he will post it again for you
