Re: CRANKSHAFT PULLEY
Posted by rdfarms on May 13, 2010 at 16:20:29 from (70.100.7.126):
In Reply to: CRANKSHAFT PULLEY posted by mathew koetting on May 13, 2010 at 15:34:52:
just got done pulling the crank pully on my sc. i borrowed a split bearing tool and a big puller from a good friend. it took a big pipe on a half inch breaker bar. thought something was going to break. it would not budge until we rapped on the end of the puller with a big hammer. then it moved a hair. we had to repeat this till it was almost off before it startedto move easily.
