Re: carb problems on Farmall M
Posted by pete 23 on May 13, 2010 at 17:41:59 from (173.87.144.56):
In Reply to: carb problems on Farmall M posted by jaker on May 13, 2010 at 17:02:51:
When chokeing that tractor it would be normal for excess gasoline to flow out of drip hole on carb if it does not start. If it ran good when you pulled it to start I would say you have some other issues like ignition causing it to not start with the starter.
